Displays information for the specified ingress RSVP-TE LSP.
| fast-reroute | Limits the display to only those LSPs with fast reroute protection. |
| ingress_lsp_name | Identifies the ingress LSP for which you want to display information. |
| destination | Displays only those LSPs that terminate at the specified IP address. |
| origin | Displays only those LSPs that originate at the specified IP address. |
| ipaddress | Specifies an IP address for an LSP origin or destination. |
| all-paths | Specifies that the display include all redundant paths. |
| detail | Displays the LSP information in verbose format. |
| summary | Displays only the LSP summary statistics section of the normal display. |
| down-paths | Specifies that the display include only those paths that are operationally down. |
N/A.
You can limit the display to egress or transit LSPs with the following command:
show mpls rsvp-te lsp [egress | transit] {fast-reroute} {{lsp_name} {[destination | origin]ipaddress} {detail} | summary}You can display information for all LSPs with the following command:
show mpls rsvp-te lsp {{[destination | origin] ipaddress} {fast-reroute} {detail} | summary}When label recording is enabled for an LSP, labels are displayed only for the ingress node (the egress label from the previous node always matches the ingress node label).
Use the following command to display information about a specific LSP:
# show mpls rsvp-te lsp jefflsp1 Ingress LSP Name Path Name Destination Next Hop I/F UpTm Flags ---------------- ---------------- --------------- ---------------- ---- -------- jefflsp1 jeffpath1 11.100.100.204 n/a 0 --PR--IV Flags: (U) Up, (E) Enabled, (P) Primary LSP, (S) Secondary LSP, (F) FRR Primary LSP (R) Redundant Paths, (B) Bandwidth Requested, (O) ERO Specified, (I) IP Traffic Allowed, (V) VPN Traffic Allowed, (v) VPN Assigned Traffic Allowed Summary of Ingress RSVP-TE LSPs named jefflsp1 Ingress LSPs (Enabled/Disabled) : 1 (0/1) Ingress LSPs with no configured path : 0 Ingress LSP Paths (Up/Down) : 2 (0/2)
Use the following command to display detailed information about a specific ingress LSP:
# show mpls rsvp-te lsp ingress "lsp598" detail Ingress LSP Name: lsp598 Destination : 11.100.100.8 Admin Status : Enabled IP Traffic : Allow #VPLS Cfgd : 0 VPN Traffic : Allow #VPLS In-Use : 0 Path Name: path598 Profile Name : prof598 Tunnel ID : 1 Ext Tunnel ID : 11.100.100.20 LSP ID : 0 State Changes : 5 Oper Status : Enabled Bandwidth Cfgd : False LSP Type : Primary Activity : Active Failures : 2 Retries-since last failure : 0 Retries-Total : 12 Rcv Label : 0x0052e UpTime : 0d:0h:3m:44s Next Hop : 11.121.96.5 Tx I/F : 11.121.96.20 - vlan1 Record Route : Indx IP Address : 1 11.121.96.5 : 2 11.95.96.9 : 3 11.98.96.8
Use the following command to display detailed information about all paths for an LSP:
# show mpls rsvp-te lsp jefflsp1 all-paths Ingress LSP Name Path Name Destination Transmit I/F UpTm Flags ---------------- ---------------- --------------- ---------------- ---- -------- jefflsp1 jeffpath0 11.100.100.204 n/a 0 --SR--IV jefflsp1 jeffpath1 11.100.100.204 n/a 0 --PR--IV Flags: (U) Up, (E) Enabled, (P) Primary LSP, (S) Secondary LSP, (F) FRR Primary LSP (R) Redundant Paths, (B) Bandwidth Requested, (O) ERO Specified, (I) IP Traffic Allowed, (V) VPN Traffic Allowed, (v) VPN Assigned Traffic Allowed Summary of Ingress RSVP-TE LSPs named jefflsp1 Ingress LSPs (Enabled/Disabled) : 1 (0/1) Ingress LSPs with no configured path : 0 Ingress LSP Paths (Up/Down) : 2 (0/2)
Use the following command to display information about all ingress down paths:
# show mpls rsvp-te lsp ingress down-paths Ingress LSP Name Path Name Destination Transmit I/F UpTm Flags ---------------- ---------------- --------------- ---------------- ---- -------- jefflsp1 jeffpath0 11.100.100.204 n/a 0 --SR--IV jefflsp1 jeffpath1 11.100.100.204 n/a 0 --PR--IV jefflsp2 jeffpath2 11.100.100.203 n/a 0 -EPR-OIV Flags: (U) Up, (E) Enabled, (P) Primary LSP, (S) Secondary LSP, (F) FRR Primary LSP (R) Redundant Paths, (B) Bandwidth Requested, (O) ERO Specified, (I) IP Traffic Allowed, (V) VPN Traffic Allowed, (v) VPN Assigned Traffic Allowed Summary of Ingress RSVP-TE LSPs Ingress LSP Paths that are Down : 3
This command was first available in ExtremeXOS 11.6.
This command and its output were modified, and the summary option was added in ExtremeXOS 12.0.
The command output was modified in ExtremeXOS 12.2.2.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
